305 TPI SWAP L98 350 CORVETTE ENGINE
Old Feb 2, 2016 | 09:09 AM
Isaac McCormick's Avatar
I have a 1988 Pontiac Trans Am GTA with a 305 TPI engine currently in it. I would like to swap it out for a L98 350 TPI engine from a corvette. I'd like to know all that would need to be done in order to correctly transfer this new engine into the car. What are things i would need to modify like the motor mounts, wiring harness, or reinforce the engine bay since the new engine will produce more torque. Any information at all will help thanks!!!
Old Feb 3, 2016 | 07:02 PM
AmorgetRS's Avatar
Re: 305 TPI SWAP L98 350 CORVETTE ENGINE
It will drop right in, it's still just a small block chevy. The only concern might be your lower TPI manifold as I believe the alum Vette heads kept the old style bolt angles.
Wiring harness, motor mounts, and engine bay will all work just fine. You aren't talking about a giant leap in power here.
Old Feb 3, 2016 | 07:08 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Will also have to drill/tap 1 bolt hole in the pass side head for the serp bracket.
Old Feb 4, 2016 | 08:51 AM
Thanks for the info much appreciated!!!
Old Feb 4, 2016 | 08:52 AM
Cool thanks for the info helps a ton!!!
NWFreerider
Jan 19, 2016 02:39 PM
jpnc
Jan 13, 2016 06:50 PM
Gran Torino
Jan 10, 2016 09:27 AM
xbazzarex
Jan 5, 2016 08:01 PM
tn_camaro
Jan 3, 2016 11:12 PM
