v6 to v8 350 carb electrical problems
Old Feb 28, 2016 | 08:47 PM
1986irocKen's Avatar
Hey guys,
Going to be putting in a carbreauted 350 with a t5 transmission into a 1986 base camaro. Going to have an aftermarket distributor, ignition box. Because it was a v6 what wiring can i pull out? im assuming i can take everything going to the computer out and the computer itself out... thanks any help is appreciated, also because im pulling it where do i run the wires running out of the ignition down the steering column and how do i run power into the car for the fuses into there? thans
Old Feb 29, 2016 | 12:04 AM
Night rider327's Avatar
Car: 1988 Camaro
Re: v6 to v8 350 carb electrical problems
You can use the factory 6 cyl wiring for most things. Cut/lengthen as needed, crimp on new ends, etc.
The starter, alt, headlights, horn, wipers, etc can stay and all can be made to work on the V8.
Yes you can remove the computer and it's wiring (comes from pass side fender)
No reason to mess with the column, fuse box, etc. All of that should stay as is.
Power is fed to the fuse box by the starter wiring and battery cable.
Brett427
May 11, 2017 09:03 PM
cutmesomeslack
Aug 2, 2009 07:09 PM
sr20fd3st
Dec 28, 2008 11:16 PM
dennisbernal91z
Sep 27, 2006 12:32 AM
