350 TPI Repeated Ignition Module Problems
Old May 20, 2008 | 04:49 PM
Brett427's Avatar
I have a 92 350 TPI setup that is in a 96 Silverado, The system was working fine, but one day would not start, Found out the ignition module was bad (Tested at autozone). Long story short went through about 6 modules (all tested bad immedatly after cranking), along with a new distributor, coil, ECM (2 times), Checked injector, coil, and distributor resistance, all good. Wiring is good, triple checked, along with injector wiring, I can not figure out what the hell is going on, any help would be greatly appreciated
Old May 20, 2008 | 05:21 PM
Rayvan's Avatar
Car: '89 Formula WS6 N10 No T-Tops
Engine: LB9 225HP
Axle/Gears: 3:45BW
Re: 350 TPI Repeated Ignition Module Problems
Are you using a heat-transfer goo on the module before you screw it down?
Old May 20, 2008 | 05:51 PM
Brett427's Avatar
Yes, i am using the thermal compound that is included with the module
Old May 20, 2008 | 08:45 PM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Get a good ACDELCO unit and that should really help.
Old May 20, 2008 | 08:48 PM
Brett427's Avatar
Ah, i hate to spend the extra money to just blow the AC delco unit, i guess i can try, I tryed a used GM one and it blew it also, so i dont see that can help
Old May 20, 2008 | 08:51 PM
midwest's Avatar
Did you check to see if any of the wires that plug into the module are shorted to either ground or power? Example b+ on the est wire could fry it. Also did you check them with the key "on" and "start"?
Old May 20, 2008 | 09:10 PM
Brett427's Avatar
Checked to ground and power, will have to check key on / start
Old May 20, 2008 | 11:24 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
The 2 prong plug should have 12 volts coming out of the pink and the white wire when the key is on. What are you getting?
Old May 21, 2008 | 03:23 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
All these units are :
A bad when installed.
Solution : buy a good one.
B killed at first power. (expensive parts being used as a fuse)
Solution : Double check all inputs and outputs.
C Ignition module is good. Tester is bad. Trouble somewhere else.
Solution : get all your modules tested at a different place.
The Factory Manual has long and boring, check this check that, type of flow charts. Some where some thing is very wrong. These units rarely go bad and usually just need replaced one time and problem gone for years.
The charts, diagrams, and alot of discussion about how to fix this is posted somewhere on this board. Search on "won't start", "no start", "no spark"
Typical trouble is unit tests good, no output. Trouble is found in the pickup coil, wiring, or spark coil. Heat related intermittents are difficult to find because the modules work fine cold when tested.
The good stuff can take more shorted outputs with out frying. People here have had better luck using the OEM GM AC DELCO ignition module.
If you are short on money and long on time. There are a lot of these modules at junkyards. The same unit is used in many different GM cars and trucks, 4-6-8 cylinder. Go to a pull your own part place and get a hand full to try. There should be some good ones in the bunch.
Old May 21, 2008 | 12:08 PM
Brett427's Avatar
What is the best way to check inputs and outputs? Ive checked to ground and 12 for each of the 4 ECM feeds, and resistance, The harness is a good harness that i got from Mike on here, and it is run good also. I had modules checked at 2 different autozones and both came up bad, One module i blew was a used GM module, if the tester is correct. Ill try to focus on other no start probs, as i recall i am not getting any injector pulse while cranking, which i know is related to the Ignition Module,
Brett
Old May 21, 2008 | 07:07 PM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Magnet rotor turns with distributor shaft.
Pickup coil reads a current flow.
Ignition module amplifies and directs, via relays, to spark coil under 400 rpm or when est wire disconnected, base timing only, no ecm involved for spark.
Over 400 rpm and with est wire connected, relays in the ignition module flip and sends the pickup coil pulse to the ecm which adds spark advance. Then back to the ignition module and on to spark coil. If no pulses to ecm no injectors pulses either.
Battery power is supplied to spark coil and ignition module applies a ground to fire the spark coil, when it is pulsed by the pickup coil. This is what the ignition points did (apply the ground), before electronics .
The pickup coil makes it's own power so any big (battery) power applied to these terminals, means instant death for the module. Shorted to ground, open, or crossed wires will not kill the ignition module at the pickup coil.
The output terminals are made to, short the battery volts and the current draw of a stock coil to ground, without any harm, and do this 24,000 times a minute (6000 rpm / 2 X 8 cylinders) for years.
Remember the heat sink grease, this is why it is needed, all that current/power starting and stopping makes a lot of heat.
It is obvious that you didn't even try or have the patience to search, but everything you need to know is right here on this board. Start looking for and reading about "no start" ect.... All the diagrams/schematics and the trouble shooting flow charts are here at TGO (buried in posts) and in the helms factory manuals.
Or you can just take it some where and change it all and pray it will cure it.
Go over to the Tech/General engine board Still need some help guys...car has no spark 88 CamaroGirl and read.
Time, Money, Knowledge
The more of any 1 you have, the less of the other 2 you need.
Old May 23, 2008 | 01:09 AM
Originally Posted by Brett427
What is the best way to check inputs and outputs? Ive checked to ground and 12 for each of the 4 ECM feeds, and resistance....
And the other 2?
Old Jun 13, 2008 | 08:45 PM
regal301's Avatar
Car: 1988 iroc-z
Engine: 350 Vortec TPI
Axle/Gears: 3.73 4th gen Torsen 10bolt
you have a bad engine ground or are using aftermarket modules,i have been burned by 10 of them in the last year,in my cars, and on forklifts at work,i only run gm modules and have had no problems since.
Old Jun 14, 2008 | 04:18 AM
Lucid's Avatar
Car: 86 Camaro Z28/ 87 Camaro IROC Z28
Engine: 5.0L TPI LB9 / 5.0 TPI LB9 w/cam
Transmission: Built 700R4 with Transgo shift kit
Axle/Gears: 3.27 9 bolt Posi/ 2.73 10 bolt Posi
You wouldnt have happened to put a 50,000V coil in the distributor when you changed it, would you? A few years back I bought one of those cheap 50,000V coils off of summit and it FRIED the ignition module.
I thought I had messed up reassembling the distributor but it turns out it was the coil. I swapped the stock coil and no change, but after I put the stock coil and a cheap Autozone ignition module in, it fired right up.
May not be applicable to your situation, but you never know...
Old May 10, 2011 | 01:58 PM
Mike M's Avatar
A few things to add to this discussion:
Repeated "bad" parts are not really bad. It is easier to blame the problem on someone else than to accept the fact that i just might be something else wrong with your system
Weak or non existent grounds will cause multiple electronic faults.
Using the wrong plugs will also cause multiple problems
Old May 11, 2017 | 09:03 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Another scenario for anyone referencing this post.
Had exactly same problem as OP ; would blow the ICM every time on a cold start after sitting for a week.(weekend warrior )
Found the answer on a marine forum where same problem is common with boat engines that are used infrequently.
Turns out with the heavy load when first cranking the long cold engine over, the starter (with higher than stock rated Optima battery ) was inducing a voltage spike back into the wiring torching the ICM.
Fitted push button OFF switch to Ign circuit so can crank engine over without the Ign on.
Once cranked several times, can start normally and engine will re-fire all day without use of the bypass
Five years on and no probs.
Ghettobird52
Jul 5, 2024 11:18 PM
db057
Aug 22, 2015 08:17 PM
wruiz
Aug 13, 2015 09:07 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
