HEI problems
Old Dec 23, 2001 | 01:48 PM
jamesbern's Avatar
HEI problems
O.K. guys here it is. I am trying to get my spark curve correct because I am experiencing an extreme case of detonation on the top end. The problem is that no matter where I set my mechanical advance, I always have about 40-42 degrees of advance without the vaccuum canister hooked up. How is this even possible? Is there a way to cut down total time? I have used every possible spring combo with no results, is something broken? What could it possibly be? This problem is making me pull my hair out and I am about ready to buy another distributor. Even when I run no vaccuum advance I have detonation. I have played with a few HEI distributors in my time, but have never experienced this. Any help would be greatly appreciated. Thank you for your time.
Old Dec 23, 2001 | 09:05 PM
jamesbern's Avatar
Got another distributor and that fixed it.
Old Dec 24, 2001 | 09:46 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
There are two things you could do:
1) Set the total mechanical advance to 36-38 degrees with the vacuum disconnected, ignore what you have at idle. If you use manifold vacuum, you'll make up for the low mechanical advance at idle.
2) Get a bushing to put in the advance mechanism that limits the total mechanical advance. If you look at the mechanism with the weights removed, you'll see what I'm talking about. Those bushings are available, sounds like yours has been removed.
Typically, you shoot for 8-10 degrees mechanical advance at idle and 36 degrees total advance (both at the crank).
Old Dec 24, 2001 | 11:32 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Sounds like your distributor was worn out. I went walking through the junk yard looking for HEI weights one day. It's amazing how many had worn out weights or shaft bushings. The drivers must have always complained about poor performance from their cars before they were junked.
I also had to troubleshoot a newer Vortec BBC. It ran very rough and already had the cap and rotor replaced by someone else. I found the distributor shaft bushing was completely worn out at the top (plastic distributor). Dropped in a new distributor and it ran like new.
Old Dec 24, 2001 | 06:47 PM
jamesbern's Avatar
I appreciated your responses, now I understand what happened.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
86CamaroDan
Sep 29, 2015 10:08 PM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
greenyone
Sep 2, 2015 03:39 PM
