Need help with 350 swap.
Old Apr 24, 2016 | 11:01 PM
Omar Diaz's Avatar
Hello, I have an 87 Iroc Camaro with a 350 engine. Recently the engine seized so it is now time to replace or rebuild it. I need your help on deciding what to do.
I have rebuilt a few 350s before but dont know if it is better to rebuild it or replace with stock crate engine or buy one at a wrecking yard.
I am not looking to gain more power or anything just looking to get a good reliable engine out of the whole situation.
So here are my questions.
1. If buying one from a wrecking yard. Does it matter what casting number the engine has? I need it to fit stock tpi setup.
2. If replacing with new crate, which one shoulf i purchase?
3. If rebuilding how much will i be looking to spend on parts machine work?
Old Apr 26, 2016 | 09:29 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Re: Need help with 350 swap.
If you found a good 87-94 TBI 350 it would be cheap and work .but you would lose 30+ horsepower to the stock L98. I would just rebuild the L98 if that's what you already have I could see you doing it under $1500
Old Apr 26, 2016 | 01:35 PM
omardiaz's Avatar
Thanks. I can probably get a good tbi from a buddy for around $300 and like I said im not looking to gain any hp out of the deal.
Old Apr 26, 2016 | 02:13 PM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
That would be an easy and cheap swap-out. The TBI 350 will most likely have a flat tappet cam (if its out of a truck) and I may would change the cam to one with a lil better specs, maybe a summit k1103. If you find a 350 TBI in a Caprice, Roadmaster, or a Cadillac it will have a roller cam and then you could re-use your L98 cam for a bit more power than the stock cam has.
Old Apr 26, 2016 | 03:16 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Find an '88-up 350 that has the roller provisions machined (B-body 350 TBI engines aren't easy to come by - light truck LO5s are a different story, and even though they come with flat tappet cam, many/most are machined for the roller parts). Assuming what you find is a TBI engine, take the heads off and find somebody that needs an anchor for their bass boat. Rebuild your L98 heads, put your cam & lifter stuff in the replacement 350 shortblock if they're still good.
Otherwise, rebuild your L98.
MantyZ28
Jul 24, 2018 07:47 AM
MantyZ28
Exterior Parts for Sale
19
May 6, 2016 11:57 PM
89irocz355
Apr 4, 2016 12:05 PM
89irocz355
Mar 27, 2016 09:52 AM
Donniemoss86
Mar 22, 2016 10:37 PM
