Rebuilt engine starts fine but dies
Old Mar 22, 2016 | 05:32 PM
Donniemoss86's Avatar
OK so I just rebuilt my 86 trans am is a 305 tpi it starts just fine first crank but after it starts it dies and cannot figure out why can some one please help would be greatly appreciated
Old Mar 22, 2016 | 05:36 PM
thtanner's Avatar
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
Re: Rebuilt engine starts fine but dies
That's not a lot of info to run on.
Any codes?
Old Mar 22, 2016 | 05:47 PM
What kind of info you want tell ya anything you think help you help me figure it out
Old Mar 22, 2016 | 10:15 PM
thtanner's Avatar
Did you do the rebuild? Did a shop?
Everything put back the way it was?
Distributor put back where it was, aka is timing right?
Old Mar 22, 2016 | 10:37 PM
bop11's Avatar
Car: 1988 GTA
Engine: VIN F 305 TPI
Transmission: AUto
Start with any codes?
Then check fuel. First impulse, low fuel pressure. Did you put in a new fuel pump? The correct fuel pump? There are more than one for the 305. Check fuel pressure
Then look for vacuum leaks. Did you connect the two big hoses at the front of the manifold? One to valve cover, one to carbon canister. The lines to the EGR and fuel pressure regulator, the AC/cruise control and other lines.
Then look at the electricals.
Knight Prowl
Apr 5, 2021 09:10 PM
gmglenn99
May 13, 2016 12:59 AM
troinfo
Apr 3, 2016 04:47 AM
Chf.BurninGlass
Mar 8, 2016 10:59 AM
Chf.BurninGlass
Mar 5, 2016 01:48 AM
