auto to 5 speed
Old Apr 27, 2016 | 06:12 PM
FULL-THROTTLE's Avatar
Car: 86 Iroc
auto to 5 speed
Hello,
Me and my son have pulled the stock 305 and 700R4 auto out of his 86 IROC and we are installing a 1970 LT1 with a T5 5 speed, my question is should there be a plate between the trans and engine?
Thanks,
Fran
Old Apr 27, 2016 | 06:20 PM
Steve86TA's Avatar
Car: To many to list
Re: auto to 5 speed
The bellhousing will bolt directly to the engine.
Old Apr 29, 2016 | 02:42 PM
danryanm's Avatar
Car: '86 Trans Amvanian Frankenbird
Engine: 350 4bbl
Transmission: T5 4.03/.76
Re: auto to 5 speed
The bellhousing will mount directly without a plate, but be mindful of what size flywheel your engine requires (many of that era block will only accept the 168-tooth flywheel, which is not compatible with the factory T5 bellhousing.) If that is the case, you will need an aftermarket unit. Even so, no plate is necessary.
BuiltZ28
Oct 13, 2017 12:02 PM
Zane Story
Apr 25, 2016 05:45 PM
Johny2234
Apr 24, 2016 10:35 PM
budowski
Carburetors
Apr 12, 2016 10:28 AM
ziggy89
Apr 10, 2016 11:35 AM
