Fuel line routing?
Old May 29, 2016 | 10:37 AM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Fuel line routing?
A few years back I went to a carbed l31, the car originally had a v6 and I was curious as to how I can route the fuel line better. Right now iv got rubber fuel line going from the driver side original metal line, acrossed the motor to the passenger side to the carb. How are you guys routing these lines because to me this looks bad and seems to be dangerous
Old May 30, 2016 | 11:44 AM
Pocket's Avatar
Car: 91 Trans Am
Re: Fuel line routing?
You have a few options
1) Bend new alum/steel lines and flare the ends
2) All new AN6 flexible lines
3) cobbled up mess of hardline and clamped on rubber splices
1) inexpensive, take a long time to do it right with the proper benders/mounts
2) Most expensive
3) Cheap and easy on all counts
Old May 31, 2016 | 10:14 PM
Engine: L31 350
2) Most expensive
iv basically got #3 right now and I'd like to get away from it. If I go with new metal line could I go with brass lines? They're normally easier to bend and handle. Would I have to take it back to the tank or could I splice in the new metal line under the firewall somewhere ?
Old Jun 1, 2016 | 12:54 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You could. Personally I think aluminum is easier to work with.
You could splice the new metal line anywhere you want.
Bubbajones_ya
Jun 12, 2016 01:46 PM
dennisbernal91z
Apr 14, 2016 05:37 AM
Rpm92
Mar 30, 2016 09:32 PM
toosloz
Carburetors
Dec 4, 2001 05:59 PM
crazeinc
Nov 29, 2000 01:33 PM
