3800 series supercharged
Old Dec 26, 2001 | 04:19 PM
1991v6camarors's Avatar
Are these motors good for these swaps? any transmission that would bolt to it for rear wheel drive, considering these motors are all in front wheel. thanks
Old Dec 26, 2001 | 05:08 PM
Kory-88Iroc 350 tpi's Avatar
Car: 88 Iroc
Engine: 94 lt1 modded
Transmission: t 56
I don't see why it wouldn't . I believe that they are the same block which is in the grand national, and the tta.
Its a great motor. My dad is on his second Grand pre gtp. I think that this is a great swap idea.
just my .02
Kory
Old Dec 26, 2001 | 07:54 PM
No5.0's Avatar
Car: Buick
Engine: 231
Transmission: 200r4
The newer 3800 is a front wheel drive version and the bolt pattern is very different.It would be a difficult task,good luck.
Sam 87 GN 88 formula<rip>
Old Dec 27, 2001 | 05:14 AM
Tas's Avatar
Tas
if you get a tranny from a 4thgen 3.8L f-body it shouldn't be too hard.
Old Dec 27, 2001 | 02:14 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
The bellhousing bolt pattern is the same on the Series II 3800 as the other 60* V6's, the problem would be possibly in engine mounts and wiring harness, neither should be a big problem, the other problem with the supercharged setup and the NA one for that matter is that the throttle body would be in the back of the motor so im not sure if there's enough clearance for an elbow to bring it around.
Old Dec 27, 2001 | 03:48 PM
Blue502's Avatar
Don't know if the swap is possible or not, but I'll definately state that I love driving our supercharged '98 Olds LSS. Smooth and pretty quick, plus good mileage.
Old Dec 27, 2001 | 08:26 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
throttlebody in the back, no problem. get a cowl induction hood, good air filter & enjoy. engine mounts will be interesting though.
Elephantismo
Feb 13, 2019 12:51 AM
92camaro350cci
Oct 14, 2015 09:29 AM
darwinprice
17
Oct 11, 2015 11:51 PM
-=Z28=-
Sep 24, 2015 10:21 AM
BLK87Z
Sep 18, 2015 11:29 PM
