cam advice needed
Old Jul 11, 2016 | 05:50 PM
senior bear's Avatar
cam advice needed
HI all recently purchased my 88 formula .had sum isues with the tbi which you guys helped me with .next problem the 305 in the car has very little compression on no 3 cyl .i have a 350 that is a 808 4 bolt block it has lt1 pistons unknown after market alloy cylinder heads that are brand new .un used id like to keep the tbi car has no cat no egr or air pump .dule exhast being maid as per ******* post in the exhast section .dus anyone have a sensible idea for a cam .the block is a roller block all standard converter 700r4 and axel dont want a drag car just a nice drive with a nice exhast note .
Old Jul 11, 2016 | 05:57 PM
BrutalGTA's Avatar
Car: 1989 GTA
Engine: LS coming soon
Transmission: 80E coming soon
Axle/Gears: S60/35 Spline/S-Trac/3.73
Re: cam advice needed
Find out what specs on the heads are. Also what gear ratio would help too.
Old Jul 12, 2016 | 03:49 AM
HI specs for heads are 64cc chambers intake 2.02 exhast 1.6 200cc port volumes .will have to get car on ramps to find axel and box ratios .
Lucky5968
May 22, 2016 02:51 PM
dixie wrecked
May 21, 2016 05:04 PM
Yooper
May 5, 2016 10:10 PM
marcus_booth
Apr 27, 2016 08:55 AM
yevgenievich
Apr 18, 2016 03:36 PM
