non ecm 350 into ecm 305 car
Old Jul 21, 2016 | 08:02 PM
Trevor Pinson's Avatar
Car: 1984 Fireturd
i blew out the 3rd and 4th clutch pacs in my firebird now im installing a used tranny out of a monte carlo and plan on using an older non computer engine my question is will i have any issues with that or can i just rip the ecm right out
Old Jul 22, 2016 | 07:26 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: non ecm 350 into ecm 305 car
If this is an LG4 and the 350 is relatively tame you can install the new motor under your existing computer controlled system, re-using everything hooked up to the old motor. It will likely require some adjustments to the carburetor to get it back in its happy range, but the amount of effort and time to do this is still substantially less than that required to tune a new carb/dist combo, at least IMO.
Old Jul 22, 2016 | 10:47 AM
Car: 1984 Fireturd
im getting a full engine ready to drop in i just want to know since its a pre computer motor will i have no problem running without the ecm system
Old Jul 22, 2016 | 12:44 PM
naf's Avatar
naf
You'll have to define 'problem'. I'd consider it a 'problem' having to purchase additional parts such as the carburetor and distributor and wire in an alternate method of converter lock. Especially if the existing carb/dist is functioning well. I might also consider it a 'problem' if, after installing these new parts, I got less than optimal mileage and driveability.
If, however, my existing system was fubar I may consider the above to be a 'solution'.
w41duvernay
Mar 30, 2016 03:03 PM
DemonYusuke
Mar 22, 2016 03:42 AM
upon2
Mar 20, 2016 09:09 PM
GTA-Force
Aftermarket Product Review
May 20, 2001 08:56 AM
Snomadnes
Oct 5, 2000 01:03 PM
