Ls1 swap
Old Jul 23, 2016 | 01:23 PM
ctoledo0834's Avatar
Car: 87 camaro Z28 convertible
Engine: 350 carb
Transmission: th-700r4
Axle/Gears: Posi traction 3.42 gears
Ls1 swap
Hi everyone looking to do the ls1 swap and found these two engine and wanted to know which one you guys think would be better to go with and which one requires less stuff to change to make it work in my Camaro. Thanks
Old Jul 23, 2016 | 01:24 PM
Engine: 350 carb
Re: Ls1 swap
Old Jul 23, 2016 | 01:25 PM
Engine: 350 carb
Re: Ls1 swap
Old Jul 23, 2016 | 02:05 PM
Engine: 350 carb
Re: Ls1 swap
Old Jul 23, 2016 | 04:26 PM
Engine: 350 carb
Re: Ls1 swap
Nobody?
Old Jul 23, 2016 | 05:54 PM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
Re: Ls1 swap
Originally Posted by ctoledo0834
Nobody?
All seem kinda high. Around here those prices would easily bring a 6.0.
Old Jul 24, 2016 | 07:38 AM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: Ls1 swap
The 4.8 is closer to swap ready but it looks like a mess, who knows internal condition if the tune was off or anything of the sort. And it's still a 4.8, which while not useless, is a whole lot less desirable. Therefore overpriced.
The 5.3 on the other hand is not close to swap ready, and has blatant lie of being out an 06 Escalade (only offered 6.0's) and as a LM7 "HIGH OUTPUT". An LM7 is a garden variety 5.3.... while a great motor, nothing "HO" nor special. Unless you get the trans with it and use that trans....it's overpriced too.
Me?......I'd keep looking.
Old Jul 24, 2016 | 09:06 AM
Engine: 350 carb
Re: Ls1 swap
Ok thanks for the info appreciate it. Looks like the search continues 😑 Lol
Old Jul 26, 2016 | 11:01 AM
kenney001's Avatar
Car: 1990 Iroc-Z
Engine: 5.7 TPI
Re: Ls1 swap
You may want to price out the parts needed to put a truck motor in your car over an LS1 before you spend $1600 on one.
You're looking at $150-$200 for the oil pan, $400-500 for the accessory drive (if you get them used), and $100-$150 for a stock LS1 intake.
At least in my case, it ended up being cheaper to get an actual LS1. I found an LS1/T56 complete pull out for $2500.
BG1959
Jul 20, 2016 02:22 PM
Mumz
Apr 13, 2016 03:42 PM
MustangEater82
Mar 31, 2016 05:36 PM
Accerrito22
Mar 25, 2016 07:25 AM
kenney001
Mar 22, 2016 07:11 PM
