oil sender unit?
Old Dec 26, 2001 | 11:52 PM
craiger's Avatar
oil sender unit?
I am in the finishing stages of a motor install on my Z28. Where does the oil sending unit go? I can not thread it into the holes above the oil filter area and that is where i took it from the old motor? the new engine is a mid 90's block? Any help would be GREATLY appriciated.
Old Dec 27, 2001 | 03:29 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
look at the back of the motor on top buy the distributor...or you could start the motor and watch where all the oil comes from....
easy to find when you forget to hook it up..thats what I did...Talk about a mess...
Old Dec 27, 2001 | 11:26 AM
84TransAm's Avatar
Just don't buy one from Advance Auto. It worked fine for a week then smoked 4 quarts of oil out of it while sitting in traffic!!!
Old Dec 27, 2001 | 03:40 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
If you are running TPI, the "hole" above the oil filter is for the backup power switch for the fuel pump. (incase the normal circuit fails, this one will energize the pump when oil pressure hits like 10PSI or thereabouts.)
The one you are looking for is right up there beside the distributor, again, if you are running TPI, you need a 90* adapter to keep the sensor out of the way of assorted obstacles. (such as the distributor........)
Have fun.
Old Dec 28, 2001 | 08:42 AM
craiger's Avatar
Thnaks for all the help! Turns out that the motor was painted and the hole was pluged so we missed it but its all good now Thanks again!
Old Dec 28, 2001 | 11:13 AM
Guest
Guest
Posts: n/a
Just a correction
TPI cars that have 2 senders (one for oil gauge one for fuel pump)are both by the distributor, the later ones have one sender and those are located by the oil filter.
Hotrodboba400
Dec 10, 2019 07:07 PM
carattini
Sep 10, 2015 07:46 AM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
Glowsock
Sep 5, 2015 07:48 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
