will vats interfear 350tbi
Old Aug 2, 2016 | 05:21 PM
Bobby Suth's Avatar
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
I have a 89 5speed rs that came stock with a 305tbi. I have a 350 tpi out of a 88 or 89. If I put a tbi intake on this 350 will vats interfear with my system? I do have a 88 tbi car I can get the engine harness and ecm from.Even the dash If I had to use it. I want to switch as little as possible. I realy hate to change out dash and steering colume. I read a post about caprice ecm.Hows vats do with that
Old Aug 2, 2016 | 07:49 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
I went from tbi to tpi and the vats wasn't a factor. Since you're planning on keeping the original configuration it will have even less bearing on your swap. You'll be fine.
Old Aug 2, 2016 | 09:06 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
Re: will vats interfear 350tbi
They say to use a 350 ecm,prom and knock sencer. Oh and 350 injectors. Third gen had no 350 TBI,so a truck or caprice ecm and prom got a be used. Will the caprice and truck ecm and prom still work in a vats equipped car?
Old Aug 2, 2016 | 09:15 PM
Ecm can stay the same. The prom needs to be different but still has no bearing on the vats. It's a separate module that sends a signal to the ecm. As long as the key and vehicle's original vats module isn't changed (which there is no reason to change) you'll have zero problems with vats.
Old Aug 3, 2016 | 09:51 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
Thank u! That answers my question. What would happen if I used that 88 TBI ecm and engine harness?I also have a harness and ecm for a 86 tpi
Old Aug 3, 2016 | 10:39 PM
Using the 88 stuff shouldn't have any affect, I don't think. Though it may need a few pins changed at the c100 or c200 but I doubt it'd be much. If you want to change to tpi you could use the 86 stuff and the same rules apply.
Chf.BurninGlass
Jul 10, 2016 12:07 AM
SRKLEGIN
Mar 27, 2016 05:57 PM
chanrahan
Mar 21, 2016 09:53 PM
bbtaz97
Aftermarket Product Review
Feb 17, 2001 01:56 AM
Gary89RS
Oct 18, 2000 01:45 PM
