tbi with vortec heads
Old Aug 17, 2016 | 10:04 PM
lowlifepunk's Avatar
Car: 86 sc
Engine: 350 tbi on the way
Transmission: t5
i have a tbi 4 bolt block atk reman with 14k miles, i got a junk vortec block with 062 heads and put them on with the flat tappet cam for right now. i plan on running a carb intake and i have a 14096242 intake but it doesnt line up at all? has anyone had experience with this intake? i wanted this motor done for the woodward dream cruise but now i just want it put together without breaking the bank, will this intake work at all? if not what is a good recommended carb intake for the tbi block with 062 heads?
thanks in advance guys.
Old Aug 18, 2016 | 07:10 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: tbi with vortec heads
A quick image search makes it look like that intake is for older heads pre vortec (1996)
You need to pick a carb and get a proper vortec intake for it.
There are a lot of choices
http://www.ebay.com/sch/i.html?clk_r...e+carb&_sop=15
Old Aug 23, 2016 | 03:49 PM
cosmick's Avatar
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
GMPP has long offered an Edelbrock-sourced TBI intake for Vortec heads, that Edelbrock never sold as their own, but the thing doesn't flow as well as stock L31 heads, and if you get it Extrude-honed, then the TB becomes the restriction. So get it bored to fit a TB from a TBI 454, and then the injectors are the restriction. Why go through all that, just to end up with 300 HP and TBI? The same investment will get you a Marine L31 MPEFI, or a Weiand Stealth Ram Vortec MPEFI.
If you're going to spend a grand, spend it on something that doesn't limit you to 300 HP.
BG1959
Jul 20, 2016 02:22 PM
Schurkey
Apr 8, 2016 12:38 AM
acerulz
Carburetors
Mar 30, 2016 09:04 AM
sdmf1383
Carburetors
Mar 28, 2016 08:45 PM
IROCKZE
Aftermarket Product Review
Sep 21, 2000 12:23 PM
