Engine pull/install tech tips?
Old Oct 10, 2016 | 09:50 AM
John Weburg's Avatar
Car: 1985 Trans Am
Engine: 5.0 LG4
Axle/Gears: BW Open diff, Too high
I have a 1985 firebird TA with a 305 and a T5. I have a 350 I just put together to toss in it. Before I dig into it though I wanted to consult the third gen gurus on what are the things are a pain in the butt on these cars? I have done a lot of swaps on C10's and mopars and they all have things that are a pain to deal with. Should I pull the engine and tranny? Should I pull the tranny first? Can I pull just the engine pretty easy? Thanks.
Old Oct 10, 2016 | 09:53 AM
bk2life's Avatar
Veteran: Army
Car: 91 WS6 GTA
Engine: 5.3
Transmission: 4l60e
Re: Engine pull/install tech tips?
if youve done swaps in other vehicles, then a 3rd gen is the same. its a bit harder with the core support not removable like a truck, but still that same. i always like to pull motor and trans, this way i can replace the trans seals easier. and while the trans is out, get it freshened up--and swap out the converter for a looser one
Old Oct 10, 2016 | 12:27 PM
skinny z's Avatar
I've found engine and trans together works about the best. It's necessary to remove the usual suspects obviously. Rad, distributor and accessories make it simpler too. The engine alone, I've found still means the trans crossmember has to be dropped. Getting the trans to engine bolts isn't the easiest either.
Old Oct 10, 2016 | 12:57 PM
BovineZro's Avatar
Car: '91 Camaro Z28
Engine: L31 5.7
Axle/Gears: 10 bolt, 3.73
I found pulling the engine and transmission together to be pretty easy, but to be fair I haven't tried pulling just one or the other. You can do it without removing the front bumper cover, but it helps. If you're working in a garage make sure you have enough overhead clearance; the car itself raises up quite a bit without the weight of the drivetrain in there so you'll need more space than you might think.
Pull the distributor cap or you WILL crack it on the firewall if you pull the everything at once. Label everything as best you can. A long prybar and help from a friend came in handy getting everything lined up properly when reinstalling. There are a few grounding points on the back of each cylinder head that seem to give people trouble. Also, on the reinstall watch out for your wiring; it's really easy to get it caught between the engine and firewall/trans tunnel and tear it up.
Best of luck!
Old Oct 10, 2016 | 12:59 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
with a manual trans I'd pull them together. Easier to install the trans to the engine with them out than fight underneath. the t5 isn't very heavy either.
with the smaller hoist you can pull them straight out the front once the bumper cover is removed.
http://i246.photobucket.com/albums/g...ps47ecf24e.jpg
Old Oct 13, 2016 | 03:15 PM
TinnMann2's Avatar
Car: 85 Firebird
Engine: 350 vortec
Transmission: 700R4 2 stage shift kit 2200 stall
Axle/Gears: 3.08
I just pulled mine a few weeks ago, my hoist hit the bumper cover so I had to take it off so I didnt damage it. That probably depends on how far your hoist can safely reach. I left my tranny in although I have a 700R4. It is very useful to have a buddy and some pry bars for separating the engine and tranny with those dowel pins if you are leaving the tranny in, they can be tricky I have found.
Other than that, its probably similar to the other swaps you have done. Good luck!
Old Oct 15, 2016 | 07:57 PM
MSgt Luttrell's Avatar
Car: 1986 IROC Z28
Engine: Carburated small block 454
Transmission: Level 3 Raptor 700R4 2600 stall
Axle/Gears: Strange S60 3:73 S Trac Posi
I've done it both ways, but I usually pull just the engine and then crawl into the engine bay to change the transmission seal. I will say this though, long tube headers add around two hours to an engine install in a third gen.
Old May 24, 2026 | 08:49 AM
Firechicken82's Avatar
Car: 82 TA
Transmission: Magnum f
Axle/Gears: Ford 9 w 4.11
Id have the car up on jack stands. Of you want the trans out w the engine, id have the car up a solid 2 ft. Leave the bumper. Pull the hood/rad out. If you are using the stock efi, leave the harness in the car. Just unplug all the sensors. Get them out of the way. Same w the power steering and A/c systems. If the efi system works well and you're not using it, id carefully remove it and save it for later or sell it. I don't think there is a main connector where you can pull the harness w engine in the engine bay. You can un hook it from the ecm and snake it thought the bulk head in the kick panel. But if you're using the stock system leave it. What you pull/leave all has to do w your build. If its just a simple rebuild, leave it all in. If it was a manual trans id say pull it all, but an auto you have options. No reason to make more work than necessary.
mynameisfrank89
Oct 5, 2016 08:26 PM
weswisehart
Sep 12, 2016 08:58 AM
1985blktransam
Aug 15, 2016 10:34 AM
havokjay
Aug 15, 2016 07:48 AM
Rodkaatz
Members Firebirds
Aug 7, 2016 12:06 AM
