Anyone swapped in an LT-1 to their existing 305 tpi five speed ?
Old Dec 30, 2001 | 09:39 AM
25thAnvZ's Avatar
Just trying to find out if the tranny will bolt up, what you did for an ECM, etc.... thinking about the swap..
Old Dec 31, 2001 | 11:37 AM
mat89RS's Avatar
lt1 or lt-1 ???? Big difference
Old Dec 31, 2001 | 06:30 PM
25thAnvZ's Avatar
lt-1
Chevy's original idea for the 25th Anv Z's was the lt-1, but they nixed it because of costs, was thinking maybe I should build the car they never did and was hoping someone else already had to give me some advice....
Old Dec 31, 2001 | 07:52 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Umm i think you mean LT1, the reason he said that was the early 70's had a LT-1 made 360 HP carbed i believe, the LT1 is the gen 2 small block, yes it will bolt up to your existing transmission, not likely to hold for long before grenading, you'll need a new engine harness and PCM, since you already have the SD computer etc, i'd put a good longblock with modified LT1 intake on there, good luck.
Fast355
Dec 2, 2016 06:33 PM
NBrehm
Aug 25, 2015 11:49 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
