Stick with my 390 forged SBC or swap up to an LS3
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Stick with my 390 forged SBC or swap up to an LS3
Yup and local machine shop work plus balancing, 1000$ or so. 500$ Take off heads cleaned up and checked for few 100$, and a 200$ ls3 intake.
Cheap easy big power
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
So what is he looking for, engine and trans?
Engine: LS3
Knowing that I want to hit 600+RWHP someday, OK if not right away what do you guys think of skipping over the LS3 and jumping right into an LSA?
The connect & cruise systems that GM offers basically give you everything you need to turn your car into a ZL1. I checked out Camaro5 forums and those guys have crazy looking TQ curves bone stock. Then they add a pulley and jump over 600 RWHP easily. Seems like a good route. Gets a 2 year 50,000 miles warranty too.
Not cheap by a long shot, but all there, new and ready to drop in. Jegs sells this for about $19K. I figure if I save up for a year plus my bonus for next year I could just about swing it. By then I should have most of my "good" stuff sold to help offset the cost.
Anyways, really just looking to see what you all think. Thanks.
Option #1: My 390 has been sitting for about 3.5 years so if I decide to keep it I will get it refreshed, dyno tuned, then add the blower, have that dyno tuned and slap that in the car, rebuild the T-56 and (from a 93 F-body, so gears are no longer available
)call it done. Induction is thru a 750 CSU aerosol blow thru carb. Dennis, does that t56 I bought off you need to be rebuilt?
Kyle
Engine: LS3
Hey Kyle, for what you need it for, it will be just fine. I would need a rebuild/upgrade for what I am planning... 700+hp to the wheels.
something more mild, like my old 450 hp 390 and it should be just fine.
When I was thinking of keeping all my SBC stuff I was thinking of having Tick Performance rebuild it with Viper internals to handle the power.
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
Option 5:
Buy a vette... best move i made.
Engine: LS3
I plan to do that in addition to the camaro. Camaro first though. Built not bought add they say.
