Small block 400/Muncie 4 speed swap help
Old Apr 23, 2017 | 01:46 PM
Jlanz55's Avatar
Soon i'm going to swap my newly built 400 into my 91z and im unsure about using a muncie 4 speed. Im on a very tight budget and cant afford a t56 right now. Muncies are very cheap around me but im concerned about swapping everything over. If anyone has any experience with this please let me know
Old Apr 24, 2017 | 08:47 AM
Jorlain's Avatar
Car: '84 Trans Am
Engine: 357 SBC
Axle/Gears: 10 Bolt 3.73, Torsen Diff
Re: Small block 400/Muncie 4 speed swap help
I don't have any experience with the Muncie, but I imagine there's a few things that are going to be a problem for you. Crossmember, Torque Arm, and the Drive Shaft.
You're not going to be able to mount your torque arm to the 4 speed. So, you're going to have to fabricate a crossmember with a torque arm mount, and be confident enough with your skills to ensure you get the angles right. Assuming that the 4 speed has a different length than whatever it is you're running right now (I'm assuming a T5) you may need a new driveshaft, too.
This is all speculation on my part. But I imagine we don't hear of too many people doing this swap for a reason.
Old Apr 26, 2017 | 03:19 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You don't need to mount the TA to the transmission crossmember. You can get a unit like the BMR Trak Pak with its own crossmember (subframe connectors required - but who in their right mind doesn't run subframe connectors?).
With a 400 SBC and Muncie, I hope you're planning on a rear end upgrade as well.
Old Apr 26, 2017 | 04:27 PM
Jorlain's Avatar
Car: '84 Trans Am
Engine: 357 SBC
Valid point! I suspect he'll still need to fabricate a crossmember, though.
Old Apr 26, 2017 | 08:36 PM
Jlanz55's Avatar
Thank for the ideas guy but i thought about it and am going with a V8 t5 because it would be much cheaper and easier. I just hope the T5 doesn't grenade in the first few weeks!
Old Apr 26, 2017 | 09:52 PM
five7kid's Avatar
Just baby it. No clutch dumps, no speed shifting.
