Crate 350
Old Aug 22, 2017 | 08:05 AM
Brandon Royer's Avatar
Car: 86' Iroc
Axle/Gears: Stock
Crate 350
First off, 86' Iroc Camaro that currently has no engine/trans/driveline. It was born with a 305/auto and I want it to be a 350/5 or 6 speed. Most likely a 5 speed because of the price of a t56. I am in between carb vs fuel injection.
Cars purpose:
This car is a Sunday driver restore project. My plan is to get the engine and trans fitted and drive it around to make sure everything works because from what I read when installing the t5, I will have to cut a hole and weld a double plate to the firewall. So I want to install everything and make sure it all fits before I do the repaint.
I chatted with a Summit tech and he referred me to this engine if I was to go with the carb.
https://www.summitracing.com/parts/nal-19210009/reviews
I was looking at all options so I want to see what people are doing that have the same generation Camaro as me.
Old Aug 22, 2017 | 08:40 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Crate 350
If I were buying a new motor I would not go flat tappet. Carb will get you going but if it is in your budget EFI is the way to go.
