Cracked head
Cracked head
i have a 427 with 840 heads what are the chances that the heads are craked and iscausing my overheating it is .030 bored
i am having hard time with that heat and thats why i am looking at a craked head or gasket
Car: 1990 RS Camaro
Engine: 400 sbc throttle body
Transmission: world class t5 manual
Axle/Gears: 3.73's, Detroit TrueTrac
Re: Cracked head
Highly doubt it is a cracked head, but possible. Either way you will have to pull the heads off to do the gaskets so you might as well check for cracks and warp at the same time. I have a hard time keeping my SBC 350 cold some times. I am assuming you have already upgraded the radiator from the stock one?....
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Cracked head
Could be a lot of different things. When is it over heating and what have you done to diagnose it?
