305 to 350 swap
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 305 to 350 swap
Bolt in deal bolts have a one piece rear main seal and same intake pattern. If it’s efi you need the memcal or prom reprogrammed and larger injectors.
Engine: 5.7L L98 TPI
Transmission: 700r4 Automatic
Re: 305 to 350 swap
Isn't one a TPI engine and other is reverse cooled LT1 derivative?
Physically would fit, but wiring, etc will be much different.
