1989 Iroc LB9 to L31 Swap
Old Feb 15, 2018 | 07:06 AM
FART_NUGGETS's Avatar
Car: 1989 Iroc-Z Convertible
Axle/Gears: 2.73:1
EDIT - Found this awesome thread:
https://www.thirdgen.org/forums/engi...31-r-swap.html
So I suppose my real question here, is.... is a $3500 budget realistic to get the swap done and the car running and driving? I would do all labor myself. So $3500 woulld need to cover the L31, intake base, headers, any other parts and accessories that I would need to get the car back on the ground and running....
Original post:
Transmission is out for a rebuild because I blew it up.
So while it's out, I was thinking of pulling off an engine swap before spring rolls around.
I am looking at the $1899 L-31 Vortec long block on Jegs, it's the HD one which I believe has the 4-bolt mains and the forged crank. There's also a 2-bolt L31 for $100 less.
I know I will need a new Vortec TPI base. I also know I'll be doing headers and a new Y. Car already has new 22-lb injectors in it from the previous owner.
What else will I need to purchase to get this swap done? I know I will need a ECM from a 350, or have mine reflashed. My LB9 is running good and I can pull anything that will work on the L31 off of the LB9.
Doing all labor myself, what would a reasonable budget be for the complete swap? I have about $3500 to work with.
Thanks!!!
Last edited by FART_NUGGETS; Feb 15, 2018 at 09:01 AM. Reason: Because I searched more.
Old Feb 15, 2018 | 12:45 PM
Axle/Gears: 2.73:1
Re: 1989 Iroc LB9 to L31 Swap
And what would be the best drop in roller cam swap for the L31? I don't want to have the heads machined so I think I would be limited to .480 at the very most, and that would require verifying clearance.
Old Feb 18, 2018 | 05:19 PM
Axle/Gears: 2.73:1
Talking to myself here
I'm at $3947 for the following parts:
L31 Motor
SDPC Vortec TPI Intake base
Reprogrammed Computer (P4 Flash)
Hooker Headers & Y Pipe
LT4 Hot Cam (.492 lift, 279/287 duration)
LS6 valve springs and retainers
intake bolts
5/16 Header bolts
intake & header gaskets.
So I'm thinking it will be around $5k by the time the engine is in the car and running. No way to do it with headers and a cam swap for anywhere near $3500....
Still don't know what I'm going to do, maybe start the build a little at a time.
Old Feb 18, 2018 | 09:07 PM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
I'm planning anL31 swap myself and I figure spending $4500. I've been buying parts and setting back a couple years. Some I may or may not use. Thinking staying TBI L31 with an 049 TPI cam, hooker headers, just a nice strong cruiser.
intex1982
Theoretical and Street Racing
Nov 21, 2019 09:01 PM
watajob
Mar 9, 2019 02:11 PM
ChrisMPG
Aug 21, 2016 10:44 AM
ace322
Mar 14, 2014 04:53 PM
JeffP
Nov 27, 2000 11:11 PM
