LT1 396 dyno
Old Feb 15, 2018 | 10:57 AM
GOTCHEVY's Avatar
Car: 97 Z28
Engine: 396 LT1 518whp All Motor
Transmission: 6spd
Axle/Gears: 4.10 LSD
LT1 396 dyno
I know this is a thirdgen forum, but I think you guys would still enjoy this video of what my car put down
Let me know what you guys think
Old Feb 16, 2018 | 02:26 AM
Neil350's Avatar
Car: 93 Trans Am
Transmission: T56 Street Twin
Axle/Gears: 12 Bolt 3.90
Re: LT1 396 dyno
Really strong numbers, I have a 24X 398" motor in my 93, cars been sitting for the past year or so with a valve train issue. Great to see other LT1 cars out there.
Old Feb 16, 2018 | 09:47 AM
GOTCHEVY's Avatar
Car: 97 Z28
Transmission: 6spd
Re: LT1 396 dyno
Thanks man....lots of work to get to this point
Old Feb 16, 2018 | 10:27 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: LT1 396 dyno
Very strong, Any motor specs you could share? cam, heads comp ratio?
Old Feb 16, 2018 | 10:34 AM
GOTCHEVY's Avatar
Car: 97 Z28
Transmission: 6spd
Re: LT1 396 dyno
Factory 4 bolt main block
Scat 3.875 crank Scat H beams Diamond pistons
Advanced Inductions custom HYD roller cam
AFR 210s ported
Factory intake manifold ported by me
10.5 compression runs on Cali 91 garbage
24x torqhead swap
6speed 4.10s out back
Old Feb 16, 2018 | 11:59 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: LT1 396 dyno
Very nice and great torque too
Old Feb 17, 2018 | 06:33 PM
GOTCHEVY's Avatar
Car: 97 Z28
Transmission: 6spd
Re: LT1 396 dyno
Thanks guys
My plan is to get another intake manifold and get much more aggressive with the porting. Probably weld in more material to get a taller runner. Also switch to monoblade, should help with more top end.
Old Feb 18, 2018 | 10:18 AM
Bow_Tied's Avatar
Car: 1987 IROC-Z
Engine: L98 5.7L
Transmission: MD8 700R4
Axle/Gears: G80 GW6 3.27:1
Re: LT1 396 dyno
Sounds great too!
Old Feb 19, 2018 | 12:18 PM
Arctic White 91 RS's Avatar
Car: 91 RS/ 99 T/A/ 72 Vette/ 02 Z28
Engine: LSx/ Dart400
Transmission: M6/ M6/ TH400/ 4L60E
Axle/Gears: 4.10's / 3.08/ 2.73
Re: LT1 396 dyno
Excellent numbers! Your car should be a lot of fun
I've seen a couple of LT1 396's fail to break 400 whp. Those had stock Optispark style ignition setups.
Old Feb 21, 2018 | 07:12 PM
Justin69's Avatar
Car: 89 Camaro RS
Engine: LT1 w/ 70mm Turbo
Transmission: Stage 3 TR6060
Axle/Gears: 4:10
Re: LT1 396 dyno
Very nice!
Old Feb 22, 2018 | 01:02 AM
zya5point0's Avatar
Car: 87 IROC
Transmission: auto
Re: LT1 396 dyno
Nice numbers, congrats! I'd don't see myself ever doing an lt1 swap on a third gen, but a mid 90's car with those numbers would be a fun daily driver and surprise a lot of ls1 guys, lol!
Old Feb 22, 2018 | 09:19 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: LT1 396 dyno
VERY NICE!!!! Good to see a traditional small block based build kicking out good numbers. I am about to use the same stroke in a .060" over 400 block with 170cc Etec170s in my Vortec Express van. Its not a high reving build but I am using 6" rods. I already have the 24x setup run by an 0411 and a ported L31 marine intake on the current 350.
Old Feb 22, 2018 | 08:27 PM
GOTCHEVY's Avatar
Car: 97 Z28
Transmission: 6spd
Re: LT1 396 dyno
Fast355
Whatever happen to that TBI engine you had on the van? I remember following your posts about it years back. Did you ever dyno it?
Old Feb 23, 2018 | 07:11 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: LT1 396 dyno
Originally Posted by GOTCHEVY
Fast355
The engine I am building is in my Express I converted to 1-ton that I pull my travel trailer with.
My old TBI in the G-van hit mid 300s at the wheels with worked Vortecs, 2" marine TBI with 61# high pressure injectors at 30 psi (~104 lb/hr each) and a victor jr 2bbl intake. Cam was too mild and compression ratio too low for any more.
The 383 TPI replacement was in the 380 rwhp range. I still have the old G20. Has a 454/502HO cammed 8.1 sitting in it. Have the engine at a point where I have test run it but I still need to swap a 4L80E into it and convert it to 4x4 1-ton running gear. Have other projects and 70-80 hour work weeks in my way at the moment.
Its a bit of a monster sized 1-ton Express van though. 1 ton suspension with a 10.5" full floating 14-bolt under it. The Vans have the same frame 1500-3500 just different suspensions. The heavier suspension literally bolts on to them.
Old Feb 23, 2018 | 08:31 PM
BlackMamba's Avatar
Car: 84 Camaro Z28
Engine: 355 Carb
Re: LT1 396 dyno
Sounds amazing
my friend had an LT1 that he let me drove man i love driving that LT1 power camaro
also car looks great
Old Mar 2, 2018 | 04:00 PM
GOTCHEVY's Avatar
Car: 97 Z28
Transmission: 6spd
Re: LT1 396 dyno
Pic of the engine bay. Theme is, make everything look as factory as possible.
Attached Thumbnails LT1 396 dyno-07776d9a-5b8c-4af1-87ce
Old Mar 16, 2018 | 06:49 PM
83z28crossfire's Avatar
Car: 1992 Camaro Z28
Engine: LS1 Swap In Progress
Re: LT1 396 dyno
is a LT1 engine compatible with a 3rd gen
KYL98
Oct 25, 2003 09:51 AM
TA-Wizard
Aug 25, 2003 10:51 PM
tamatt27
Apr 2, 2003 10:09 PM
blown4now
Sep 26, 2002 09:58 PM
89vette
May 14, 2001 08:08 AM
