Questions and suggestions about swapping a older l98 into a 91 rs
Car: 1988iroc z and 1991 Camaro Rs
Transmission: 4 speed and 5 speex
So I have a l98 from a 88 iroc with its older computer and harness and a 6 speed from a 95z. Swapping into a 91 rs with a 305 5 speed. My question is would I be better off using my tbi harness and finding a speed density computer or just use the older computer and harness?Anyone due a similar swap? have some tips?
Re: Questions and suggestions about swapping a older l98 into a 91 rs
You'll need to use the L98 harness and it'll be easier to use its ECM as well.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
That would take a lot of work to make an '88 harness work on a'91
I'd either find a 91 TPI harness, mod the TBI harness, or find a 3.1L harness and mod it. Of course all of these options mean sourcing a 7730 ecm and the TPI memcal, which isn't easy to come by.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
https://www.thirdgen.org/forums/engi...d-density.html
You can allways get the memcal reprogrammed if it’s for a automatic.
As long as it’s not all spliced that’s a great deal for the harness and ecm.
Being from a bird some of the connections might be short like the ccp.
Randy82WS7
Jan 24, 2012 06:44 PM
