Water in block
Old Jan 5, 2002 | 03:50 PM
kabar14342's Avatar
Water in block
i bought a block a few weeks ago wrapped it up in a tarp and had to leave it outside while i was at school, i was working on it today and it has water all inside of it, any suggestions on how to get water out of a block, i mean the waters every where down the shaft for the distributer into the oil pump, and i think it ended up down the intakes into the cyl. let me know what to do
matt
Old Jan 5, 2002 | 05:15 PM
83 MidniteZ's Avatar
if the engine doesn't have the pan on it, the water in the oil system should all come out the bottom. You can remove the plugs at the sides of the block to drain the coolant system. If you are planning on using this clock, I would make sure you get it drained quickly as to prevent rust.
Hotrodboba400
Dec 10, 2019 07:07 PM
customblackbird
Oct 1, 2015 04:30 PM
Formula8r89
Sep 22, 2015 04:24 PM
84redta
Sep 19, 2015 09:58 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
