Need Help! Post LS swap issue
Old Apr 28, 2018 | 02:08 PM
Project _redrkt's Avatar
Car: 1992 Z28
Engine: 5.3
I've got a 92 Z28 with a 5.3 out of a 04 Silverado and I have an issue that has been driving me nuts.
Issue: Startup vehicle and it will start and run well for a couple of seconds and then shut off, try and restart it and it cranks but won't start. Checked for spark and no spark is present. Read a few threads on other forums which all pointed towards a bad crank position sensor. Replaced sensor and same issue persist. Hooked up my scanner and indeed it is picking up an rpm signal which rules out the crank sensor or its wiring. The vehicle has a brand new Walbro 255 which kicks on when the ignition is turned to on. I'm running out of ideas as to what may be the cause of this issue. Any help would be greatly appreciated.
Old Apr 28, 2018 | 10:55 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: Need Help! Post LS swap issue
You didn't make mention of pulling diagnostic codes.
Old Jul 19, 2018 | 07:38 PM
MikeP_82's Avatar
Car: 1982 Camaro Sport Coupe
Engine: 2.8
Transmission: Saginaw 4-spd
Did you remove vats?
C-Titan
Mar 23, 2015 07:48 PM
Lumarus
Jul 25, 2011 08:14 PM
S10Wildside
Mar 28, 2003 07:13 AM
MILT
Dec 12, 2002 02:14 PM
chuck6860
Jul 23, 2002 09:36 AM
