No applause, Just throw money :)!!!
Old Jan 7, 2002 | 02:07 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Here's a usefull link to a web page that I found tonight.
It has calculators for these following uses. I know we already have some here. Just letting you know what this site has. It does have a few that we don't have.
1. Figuring your HP by using either your 1/4 mile ET, or your Trap Speed.
2. Tire diameter based on the size printed on the sidewall.
3. MPH to RPM in steps of 500 RPM Starting with 1000RPM and going to 7500RPM
4. Rear end Gear Ratio
5. CFM needed for an engine (given for 4 bbl carbs).
6. Compression Ratio!!!!!!!
7. And finally, 1/8 to 1/4 conversion chart.
There's also a tech link that will give you the actual formulas. That way you can wear out a pencil if you wish to.
Plus a few links to well respected manufactures of HI-PO parts, etc.
AJ
http://www.ondoperformance.com/
Old Jan 7, 2002 | 02:41 AM
AJ_92RS's Avatar
TTT......
Sorry....... I forgot to actually put the link here......DUH!!!!!
AJ
Fanatic1074
Oct 3, 2022 05:57 AM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
racereese
Oct 3, 2015 03:46 PM
ndndndnd
Sep 28, 2015 08:00 AM
