88 iroc z
Old Oct 21, 2018 | 03:18 AM
freaky's Avatar
Car: 88 camaro irocz
Engine: l98 tpi
Axle/Gears: 2.77
88 iroc z
im back after a few years of being gone . got rid of my 92 rs . now im back with a 88 iroc z . im putting a 5.3 with a 7875 turbo . th400 tranny im putting a stage 2 btr turbo cam
right now im jus buying parts . hopefully ill get the engine in the car in the spring
92 rs gone
Old Mar 25, 2019 | 10:48 AM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
Re: 88 iroc z
Old Mar 25, 2019 | 10:50 AM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
Re: 88 iroc z
i got a 5.3 coming today . should have old engine out an new engine installed in two weeks
Old Mar 25, 2019 | 06:15 PM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
Re: 88 iroc z
lm7 . 2001 05.3 with 225000 miles no knock doesnt burn oil
Old Mar 25, 2019 | 06:29 PM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
Re: 88 iroc z
im going with a speedmaster intake an a 92 mm throttle body https://www.hotrod.com/articles/20-l...ifolds-tested/
Old Mar 29, 2019 | 12:48 AM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
Re: 88 iroc z
FBODY OIL PAN
Old Mar 29, 2019 | 12:53 AM
WildCard600's Avatar
Car: 1989 Trans Am
Engine: sp357
Transmission: TKX
Re: 88 iroc z
Interested to see how this turns out.
Old Mar 29, 2019 | 12:49 PM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
Re: 88 iroc z
thanks man im gonna get it running na then over the winter put a 7875 turbo on it should be around 500-550 whp
Old Mar 29, 2019 | 12:53 PM
Car: 1989 Trans Am
Engine: sp357
Transmission: TKX
Re: 88 iroc z
Nice. Should scoot along quite nicely with 500 hp.
Old Mar 30, 2019 | 07:39 AM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
Re: 88 iroc z
im hoping for low 10s around 130 ish
Old Apr 2, 2019 | 04:29 PM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
Re: 88 iroc z
Old Apr 2, 2019 | 05:44 PM
Car: 1989 Trans Am
Engine: sp357
Transmission: TKX
Re: 88 iroc z
I need a MIG.
Old Apr 3, 2019 | 03:15 PM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
Re: 88 iroc z
I need a MIG.
i got one .im thinking about a spool gun . then a friend sent me this video . hopefully it works good an saves me 200 bucks on a spool gun
Old Apr 3, 2019 | 03:26 PM
Car: 1989 Trans Am
Engine: sp357
Transmission: TKX
Re: 88 iroc z
From the video it seems like it would work fine for occasional use. If you are planning on doing a lot of aluminum welding, I think I would spring for the spool.
Old Apr 6, 2019 | 08:46 PM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
Re: 88 iroc z
got the engine on the stand today .
Old Apr 6, 2019 | 08:47 PM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
Re: 88 iroc z
jason donate older style iroc wheels
Old Apr 6, 2019 | 08:50 PM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
Re: 88 iroc z
the old locked up l98 350 waiting to get pulled
Old May 9, 2019 | 08:40 AM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
Re: 88 iroc z
i jus ordered the summit stage 2 turbo cam . anybody know what length pushrods im gonna need ?
Old Jun 2, 2019 | 07:58 AM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
Re: 88 iroc z
Old Jun 7, 2019 | 05:14 AM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
Re: 88 iroc z
i just ordered a gt45 ebay turbo with oil lines https://www.ebay.com/itm/GT45-V-Band...947b%7Ciid%3A1
Old Jun 10, 2019 | 01:17 PM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
Re: 88 iroc z
Old Jul 29, 2019 | 05:33 AM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
Re: 88 iroc z
i bought the fuel lines i gpt a 450 fuel pump . got sum decapped truck injecters that flow tested at 75.4 . i got the accessarys an brackets an a truck wiring harness an ecu from a 02 truck .im picking up a th350 with a shift kit tommorrow . about ready to start putting it all together
Old Jul 30, 2019 | 09:35 PM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
Re: 88 iroc z
i gpt the th350 now i need torque converter an tans crss member an lines
Old Jul 30, 2019 | 11:39 PM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
Re: 88 iroc z
PARTS AN PRICES TO DATE
: windsheild 40.00 ls swap motor mounts 30.00 t4 merge pipe 26.00 blowoff valve 3" pipe 20.00 50 mm blow off valve 40.00 , . fbody oil pan 50 .00 . engine stand 47.00 5.3 lm7 100.00 FBODY OIL PAN 50.00 truck intake 50.00 pushrod tool 25.00 summit stage 2 turbo cam 259.00" carbon fiber hood 300 valve springs an retainers 235 wiring harness ecu truck accessarys an coil packs 165 complete fuel lines 450 pump an decapped 75.4 injecters 300 th350 w shift kit 150
__________________
Old Aug 21, 2019 | 12:24 AM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
Re: 88 iroc z
i run into a problem putting last 4 springs in . air pressure kept leaking down an valve was dropping . so im gonna pull heads an go ahead an change lifters to ls7 lifters an a ls9 head gasket an arp head bolts. trick flow duel springs .600 lift
Old Oct 5, 2019 | 09:20 PM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
Re: 88 iroc z
4" carbon fiber cowl hood
Old Jan 14, 2020 | 05:44 AM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
Re: 88 iroc z
Old May 26, 2020 | 01:12 AM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
Re: 88 iroc z
super auto two piece truck intake 68 dollars
Old Jul 26, 2020 | 09:38 PM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
Re: 88 iroc z
i traded the th350 for a 06 gto t56 . i also got the cam in yesterday
Old Aug 31, 2020 | 02:01 AM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
Re: 88 iroc z
im thinking about using holley terminater x to tune this . i was gonna use hp tuners but i think this will work better . whats everybodys opinions or experiences
Old Aug 31, 2020 | 02:03 AM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
Re: 88 iroc z
Old Jan 17, 2021 | 01:41 AM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
Re: 88 iroc z
Old Jan 21, 2021 | 11:35 AM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
Re: 88 iroc z
Old Jan 30, 2021 | 07:17 AM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
Re: 88 iroc z
i ordered
speed engineering headers since im gonna run na for a while
Old Feb 13, 2021 | 06:02 AM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
Re: 88 iroc z
i ordered nitto nt555g2 285/35/18 front an 295/40/18 rear
Old Apr 11, 2021 | 09:37 PM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
Re: 88 iroc z
Old Apr 11, 2021 | 09:38 PM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
Re: 88 iroc z
i just ordered a b&m shifter for the 700r4
https://www.ebay.com/itm/B-M-Automat....c100227.m3827
Old Apr 15, 2021 | 04:07 PM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
Re: 88 iroc z
Old May 7, 2021 | 04:30 PM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
Re: 88 iroc z
i ordered a set of 243 heads refurbished .
Old May 12, 2021 | 10:46 PM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
Re: 88 iroc z
Old Aug 8, 2022 | 11:55 PM
fricke1's Avatar
Re: 88 iroc z
Old Aug 8, 2022 | 11:56 PM
  #42
fricke1's Avatar
Re: 88 iroc z
jtaliaferro
Jun 23, 2020 06:17 PM
1bad91Z
Dec 19, 2012 02:46 PM
sadler
Members Camaros
19
Jun 12, 2009 06:59 PM
87PontiacBeast
Jun 27, 2003 03:52 PM
