305 with 350 heads
Car: 02 avalanche and a 84 camaro
Engine: Putting a 305 in it
Transmission: Automatic sadly
305 with 350 heads
Hey y’all so I’m building a 305 and I’m gonna put 350 heads on it which I know will lower my compression but I’ll get more power at the top end but my question is how do I get the compression to go up again.
Engine: 4++,350 & 305 CIs
Re: 305 with 350 heads
Put C4 vet aluminum heads on it or iron 305 vortec heads.
Car: '88 IROC T5 Vert ‘13 Vette
Engine: 305 TBI
Axle/Gears: 3:08
Waiting in Ft Myers airport 7 hrs to ORD departure.
305 Bore kit LOL Good ol’ Sofa.
“Wouldja just put a L31 350 in it!”
Thanks you guys, I am on a very small budget imdont
make very much money I’m just a tow truck driver. I bought the motor for $200 that’s why I’m using the 305 for now. So
What is a cheap way to up my compression with the 350 heads
If that is the route you are going to take, then use the thinnest head gasket possible.
Part #s for this include castings ending in 638, 880, etc. There are acoupla more but it's eeeeeeeezie to find em in the buzzard nest. 96 - 2000 trucks are a great source. They're CHEEEEEEEEEEEEEEEEEP. Cheeeeeeeeeeeeeeeper than any of the alternatives I can think of for getting the correct compression under 350 heads.
About the STOOOOOOPIDEST thing you can do, is to "build" a 305. As cheeeeeeeeep as the above-mentioned upgrades are, you have to have a head full of sand to spend money on a 305.
What is YOUR head full of? Sand? Rocks? Sawdust? The proof is in your decision.
You WASTED your $200 if you spent it on a 305. Throw it in the trash, take your lumps, learn your lesson, and move on.
TADailyDriver
Mar 16, 2008 04:38 AM
KZad
Feb 26, 2003 03:25 PM
