350 swap
350 swap
I currently own a 91 Firebird with a 305 tbi. I just bought a 5.7 tpi from an 88 vette that i wanted to drop in the Bird. Trying to figure out if i want to continue using the Tbi intake or convert completely to tpi. And if im swapping completely, should I buy a tpi harness or modify the tbi harness. Thoughts/opinions?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 350 swap
Even thought you don’t have a 746 ecm the pinout is the same.
https://www.thirdgen.org/forums/tpi/...d-density.html
Re: 350 swap
SS-84
Jan 19, 2005 03:54 PM
