92 Rs 305 TBI to 89 L98 165 swap.
Car: 92 Z28 Clone
Engine: Vortec 350
Axle/Gears: 3.23 Torsen
So I'm looking for someone who has done this swap. If you would be so kind to drop some info on this swap. I have a 89 350 L98 TPI with the 165 ecm complete harness and ecm that i want to swap into my 92 rs with tbi. What did you need to modify for this to work.
Car: 92 Z28 Clone
Engine: Vortec 350
Re: 92 Rs 305 TBI to 89 L98 165 swap.
Gonna be picking up a 730 ECM and repinning my 165 harness. Seems like the way to go.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Why not source a 90-92 tpi harness in the classifieds.
Engine: Lb9
Transmission: M20
Or repin the tbi 746 to 730
https://www.thirdgen.org/forums/tpi/...d-density.html
https://www.ebay.com/itm/90-92-Camaro-Firebird-TPI-1227730-ECM-Connector-Kit-Speed-Density-Computer/200905805323?epid=1155539037&hash=item2ec6eb4e0b:g:EjQAAMXQgb1RPrM4
besides the wiring , You need a new fuel pump & you need a new knock sensor for 90-92 it’s a 3.9k ohm in resistance compared to the 100 ohm tpi maf. You might want to consider a new plenum too so the map has its own vacuum signal.
https://www.ebay.com/itm/89-90-91-C4...YAAOSw4b1cPU0K
Car: 92 Z28 Clone
Engine: Vortec 350
https://www.ebay.com/itm/90-92-Camar...QAAMXQgb1RPrM4
327_TPI_77_Maro
Mar 13, 2016 07:19 PM
