CANT FIND A STARTER
Old May 3, 2019 | 10:59 AM
Nick_Dell's Avatar
Car: 91 RS
Transmission: WCT5
CANT FIND A STARTER
Put a 70s era 350 in and it only has the staggered bolt pattern. No 153 tooth starter will fit because the snout hits the bellhousing. I need some advice here. 91 RS with the wct5
Old May 3, 2019 | 12:02 PM
GeneralDisorder's Avatar
Re: CANT FIND A STARTER
Use a snout-less mini-starter if the snout is the problem. Beware that 70's blocks can have The Starter Bolt Alignment Problem. Wherein no amount of shimming will fix the starter gear alignment and they will eat starters just because 70's garbage GM machining.
I really enjoy my Meziere TS400DP. No snout on it, and dual bolt pattern. Beast of a starter. I believe they also make staggered models.
*EDIT* - seems like that's a lost cause. You can't find a starter that's for the small 153 tooth flywheel with a staggered bolt pattern. That wasn't a thing. So you need a 168 tooth flywheel.
GD
Old May 3, 2019 | 01:46 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
168 flywheel won't fit in the T5 bell without some effort, which I wouldn't recommend. There's pic on a thread somewhere here showing one hacked up.
drill and tap the starter bolt hole you need. I suspect you'll find no other option.
Old May 3, 2019 | 02:28 PM
OR - just stop using 70's garbage blocks.
GD
Old May 3, 2019 | 03:35 PM
Drew's Avatar
Am I still a hater if I point out this is one of the many reasons not to build 60s-70s engines?
Old May 3, 2019 | 04:31 PM
There IS no starter like that. I've typed why so many times I'm tired of it.
Take it back out and add this hole. Then use any starter for 12.8" flywheel.
That's about a 73 or 74 400 block that I did it to in the pic.
Old May 3, 2019 | 05:37 PM
All blocks prior to '96 Vortec are dead to me. I think you're in the clear.
GD
Old May 3, 2019 | 09:58 PM
Drew's Avatar
I don't miss the lakes of oil on the driveway, in the garage, etc... Multi-piece pan gaskets and main seals. Or cork valve cover gaskets... Don't miss engines and transmissions so caked in grease and dirt that they're just constantly oozing. Starters that don't fit, dipsticks that hit the manifolds... Just not worth messing with old engines.
Ralphm2425
Dec 29, 2018 09:31 PM
blatchp
Oct 1, 2009 02:40 PM
BlackSunshine84
Jan 5, 2006 11:49 AM
5150wraith
Apr 30, 2001 08:18 PM
