Flexplate problem cant find a starter to fit
Old Sep 30, 2009 | 08:55 PM
blatchp's Avatar
Car: 91 rs
Engine: 305 tbi
i swapped from a 305 tbi to carbed 350 and kept the 700r4 tranny for now.. i used a 70s block with 14" flexplate now i cant find a starter to work for it.. Ive tried one for a 1991 camaro with 350, 70 camaro with 350 starter and 75 with 350 and 80 with a 350.... im drawing a blank and the starter for the 1991 will not line up without hitting the flexplate and the other years barely caught the teeth on it any ideas?
Old Oct 1, 2009 | 02:09 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: Flexplate problem cant find a starter to fit
You need a 153 tooth flexplate and a block with the starter holes in a line (not staggered). Im not sure how big the 168 tooth flexplate is, so Im not sure if that's what you have, but I think you should look into that.
If you have staggered starter bolt holes you have to use the old style starter and larger flexplate... but I dont think a 700r4 will fit around it.
Old Oct 1, 2009 | 09:14 AM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
You just need a starter with staggered holes. Once upon a time you could actually go in and buy one based upon that description...... You'll need the right length bolts too.
Old Oct 1, 2009 | 02:40 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
168 tooth = 14".
You can do:
Mini starter
Truck starter
153-tooth flexplate ('82-'85 f-body V8 application)
With the 153-tooth flexplate, you can use a standard 3rd gen f-body starter. Although more work, the flexplate would be less expensive than the starter options. If you have or will have headers, you'll want either the mini starter or 153-tooth flexplate.
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
milk
Aug 10, 2015 06:26 PM
gwade12
Aug 8, 2015 08:17 AM
