L31 Balancer and timing cover?
Old May 11, 2019 | 01:45 PM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Axle/Gears: 3.23 Torsen
Just got my L31 crate from Chev Perf and was told I could use the supplied balancer, timing cover and just plug the crank sensor. But looking at it, the balancer is a lot thinner so the serpentine pulley on the crank will not align with the rest of my accessories/brackets. (92 TBI). Should I just swap in my TBI balancer and timing cover?
Old May 11, 2019 | 03:30 PM
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
Transmission: 5 speed
Re: L31 Balancer and timing cover?
from my understanding the harmonic balancer is spaced out to match your accessories by the reluctor wheel(from the fuel injected application),in the stock vortec l31 there is a reluctor wheel behind the timing chain cover that actually moves the balancer out into the correct position.im building what you have right now and this is the info ive found.can you eyeball the accesories to verify,or test fit them before installing it all to check?
Old May 11, 2019 | 03:47 PM
GeneralDisorder's Avatar
You can pull the L31 stuff off and use your standard TBI parts instead. Though I recommend a new balancer or better yet a Fluidampr.
GD
Old May 11, 2019 | 04:04 PM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Ok yeah that's what I read also and that the balancer on the L31 has a smaller snout. But by the looks of it it wont line up, I eyeballed the setup on the TBI from the balancer to the timing cover........so if I were to just grab the crank pulley and bolt it to the L31 balancer just the way it sits it would sit to close to the timing cover not aligning with my other acc pulleys. Im gonna mock it up real quick and see if it will work.
Old May 11, 2019 | 04:06 PM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
GD
Yeah that's what I think I'm gonna do. I thought about putting some washers in between the pulley and balancer but that's just not right. But it might work haha.
Old May 11, 2019 | 04:40 PM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Well, getting ahead of myself. I mocked it up and it lines up perfect. Gonna keep the plastic timing cover for now. I don't wanna mess with the oil pan gasket. Always jumping to conclusions.
intex1982
Theoretical and Street Racing
Nov 21, 2019 09:01 PM
evilstuie
Apr 10, 2015 04:41 AM
SlickTrackGod
Nov 26, 2012 05:14 PM
Rob D
Aug 28, 2008 08:04 PM
blue86iroc
Feb 14, 2007 03:23 PM
