what is that black box for
Old Jan 9, 2002 | 06:38 PM
88NOSTA's Avatar
need to know what the black box under the hood is it has 2 wire that hook to it and that's all i know i doing a 350 swap and its not with the parts i have.
Old Jan 9, 2002 | 08:04 PM
84LT-4's Avatar
The black box in your picture is a diverter valve for the air pump. the valve is activated by the computer. the valve diverts air to the exhaust manifolds or the cat depending on weather the engine is cold or hot hope this helps
Old Jan 9, 2002 | 08:59 PM
88NOSTA's Avatar
is that the name of the part? diverter valve
Old Jan 9, 2002 | 09:40 PM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
Yea, that's the air diverter valve. If you aren't running smog stuff you probably won't need it. But Michigan is a nice state, run your emissions equipment.
Old Jan 10, 2002 | 10:42 AM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
It's called the AIR diverter valve or PEDES valve.
If you keep your AIR pump and AIR headers/manifolds and cat you'll need it. If you're not going computer-controlled, then you don't need it.
Old Jan 10, 2002 | 11:40 AM
88NOSTA's Avatar
yes i keeping the computer and i cant seem to find that part boneyards wont sell one of a motor and a dealer want's $350 for one.
Terrell351
Jun 13, 2021 01:13 PM
Casey Meyers
Mar 2, 2016 10:46 AM
MantyZ28
Jan 18, 2016 08:30 AM
Dyno Don
17
Nov 2, 2015 11:43 PM
zayne0
Aug 24, 2015 07:22 PM
