Lt1/lt4
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Its been talked about a lot here,all the information you need is on here, do a search if I leave anything out,
Custom fuel lines.
Custom p/s lines.
86 up flywheel/flexplate- depending on your application.
LT1 radiator and hoses.
Headers preferrably- for 82-92 f body.
Extra O2 sensor fitting, weld into drivers side of Y pipe or header.
Custom harness or modified stock harness.
Extra info:
A/C - need to weld pass side engine mount to support pump.
Non A/C - Get 1LE a/c delete idler, fits in without any modification.
With 6 spd- Need to fab trans. crossmember or buy pre fabricated, Spohn has several to choose from www.spohn.net
Stock Exhaust manifolds will bolt up, but dont cover the ports properly, headers highly recommended.
Custom fuel lines.
Custom p/s lines.
Extra info:
