‘89 350 swap
‘89 350 swap
So I have an ‘89 Camaro with a 305 in it, im
looking to swap an earlier carb 350 into it, what all do I need for the swap? I’m aware the exhaust will most likely need to be changed because of how restrictive it was for the 305 but anything else? My first swap so any and all help is appreciated
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: ‘89 350 swap
You should use the search feature of this site.
tons of great information on the subject.
Car: 86 Iroc-Z
Engine: 383 HSR
Re: ‘89 350 swap
I remember when first stumbled onto this site, I didn't know how to navigate it or find what I was looking for. This was the first time I ever even used any forums, so maybe this will help. At the top of the page in the red, go to forums, then tech boards on the drop down, and over to engine swap and click on it. It will have "stickies" on the top of very helpful/common threads. I suggest you explore all of the drop downs. If you are searching for specific information (motor mounts or radiators, etc) go to the top right and enter it in the search feature to search forums and they will pop up when they have the search criteria you were looking for in them. GL and welcome to a great site that has everything you could possible need!
