what year block do i need to put on Vortec heads?
Old Jan 14, 2002 | 06:23 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
i might b gettin some
Old Jan 14, 2002 | 07:34 PM
Guest
Guest
Posts: n/a
1955 or newer SBC.
You will need a specific manifold for the heads though.
Old Jan 14, 2002 | 08:39 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
yah i already planned on getting the performer RPM manifold for the Vortec heads
well this one guy told me i would need the NEW STYLE block cuz of the bolt pattern
but ok
thanks!
Old Jan 14, 2002 | 08:48 PM
83 MidniteZ's Avatar
The vortec style heads fit on both the older blocks and the newer blocks. The bolt pattern has to do with the way the manifold fits on top of the heads not the block. Just get that edelbrock you want for vortec heads and you will be alright. Of course if your old heads are the older style heads you will need new narrow bodies self aligning rocker arms to clear the centerbolts.
Old Jan 14, 2002 | 09:58 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
well i am buildin the motr from scratch and i was gonna get the heads from JEGS
so what kinda rocker arms do i need?
anything else special
like valve covers or anything?
thanks
Old Jan 15, 2002 | 01:24 AM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
you will need centerbolt valve covers.
-brian
Old Jan 15, 2002 | 01:59 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
If the heads come through with stock vortec production valvesprings you'll need to upgrade those. Crane, Comp, ISKY
have stock diameter non-machineing high perf replacements.
The valve retainer to valve guide seal clearance should be checked and increased for your cams nonstock lift. Usually only enough clearance for a .450" lift cam. An easy machining operation. These upgrades may or may not be included from Jegs.
Self aligning '87 and up type rockers are required unless you install screwin studs and guideplates. A simple pocked port and polishing job on the exhaust port is well worth it. 20+ cfm
Attached Thumbnails what year block do i need to put on Vortec heads?-fb2a.jpg
Old Jan 15, 2002 | 04:00 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
'88-up for self-aligning rockers.
For all that work and expense, you could get a set of World Sportsman II's that would flow as well (with the same amount of porting to either head), and any "normal" intake manifold will fit. Springs will take the lift, screw-in rocker studs are standard, standard rockers are all that's needed. They'll also have 2.02/1.60" valves.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
