swapping a 1991 camaro
Old Feb 4, 2021 | 01:40 AM
slushy's Avatar
hello i a 1991 chevy camaro and i want to put the best engine there is in horsepower like I'm trying to get about 500 - 650 horsepower so i can race it and have fun with it . the car don't have an engine nor trans at the moment and my budget is about 10,000 i hope it ant gunna cost that much tho. i also would like to keep it the way it looks so no engine sticking out the hood pls
Old Feb 4, 2021 | 11:49 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: swapping a 1991 camaro
10,000 isn't really going to be enough, certainly for an NA setup. You are likely looking at turbo territory (5.3 + turbo). Before you spend a single penny, read, read, read and read some more. There is plenty of info on this site to give you an idea of how you want to approach your project. The devil is in the details and details cost money.
500 to 650 is a huge range. I'd narrow that down. Its like saying your budget is 10k or 30k. When you are over 500hp every additional pony becomes that much more expensive.
Old Feb 4, 2021 | 10:53 PM
slushy's Avatar
well then um i guess I'm not gonna make it a play car then put i do want to put a different engine cuz i dont like the sound of the original engine the v6 that's why i sold it so if you can give an engine that sounds like a loud chevy truck that would be nice
Old Feb 5, 2021 | 09:50 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
What are your actual goals for the car? It doesn't sound like you know what you want. Horsepower makes sounds, not vehicle types.
Old Feb 6, 2021 | 08:04 AM
Black 84 Z's Avatar
Car: 1984 Z28
Engine: 350ci
Axle/Gears: 3.73 12 bolt
Unfortunately 10k is not going to sniff 650 and likely not 500 with any level of safety. Since it has no engine or trans don't bother with anything older than an LS engine and trans. The truck engines can be had for pretty cheap and you are a cam swap away from a legit 350-400 hp at the crank and still have money in your budget to replace the other systems (brakes, cooling, rear end, better suspension) that a original V6 car would need upgraded to maintain safety. If you do the work yourself you might be able to come in at your budget and have a heck of fun car that sounds good and gets good mileage. As said before, read EVERYTHING you find on these cars and LS swaps and take your time. It will be a long process but worth it if you stick to it. Good luck!!
leo27030
Dec 12, 2020 07:36 AM
KMK454
Members Camaros
91
Jan 19, 2019 08:38 AM
michaelpeerman
Oct 3, 2010 12:06 AM
1983camaro
Jan 21, 2003 08:01 PM
