388ci stroker swap
Old Apr 25, 2021 | 08:06 PM
Voltage_Drop's Avatar
388ci stroker swap
Here is my 1987 Camaro Z28 with a 350 4bolt main from a 76 camaro. Bored. 60 over, 400 crank, machined block for clearance of crank. I have big plans for this car. What do you guys think?
Old May 3, 2021 | 05:14 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: 388ci stroker swap
Looks good! Good luck with the build!
Old May 5, 2021 | 07:08 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
My biggest concern would be the .060" overbore. Unless it was sonic checked to know if the cylinder wall thickness is okay.
Old May 7, 2021 | 10:43 PM
vorteciroc's Avatar
Top Answer: 1
A GM cylinder-block with 0.060" over cylinders???
You are far braver than myself!
You best stay away from any type of power-adder.
j_camaro_67
Jan 7, 2010 10:49 PM
daves12secV6
Feb 4, 2007 01:09 PM
84H.O.Trans Am
Mar 10, 2004 10:43 AM
