408 sb
Old Jan 5, 2010 | 10:16 PM
j_camaro_67's Avatar
Car: dark hunter red 84 camaro
Engine: 414 stroker
Transmission: th350
Axle/Gears: 3:70
408 sb
has any one built a 408 stroker from a small block 350 block. i know a guy that builds big cube small blocks right now he is doing a 427 from a 350 block. how much more would a 408 be compared to a 383 stroker he says just the crank would have to be a 4" stroke 5.7 rods and a compression height of 1.275. i am going to go with all forged so if i ever wont to put some juice to it i can, but still make alot of power with just motor. what size cam, is it worth doing a 4/7 swap. thanks jason
Old Jan 5, 2010 | 11:00 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 408 sb
If you're going to go through all that, you might want to consider starting with an aftermarket block. Fitting a 4" stroke crank in requires some pretty heavy clearancing around the oil pan rails and cylinder bottoms, and you can run into the water passages.
Old Jan 5, 2010 | 11:03 PM
Engine: 414 stroker
Transmission: th350
Axle/Gears: 3:70
Re: 408 sb
i have been looking at some after market blocks. will look in to it some more and pricing. thanks
Old Jan 5, 2010 | 11:14 PM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
Re: 408 sb
A 427 is a 400 block with a 4" stroke crank, fitting a 4" stroke crank in a 350 block, id almost guarantee, youd be grinding into water, thats ALOT of material to remove from the block, Id look at the Dart SHP series, in 4.125" bore, put a 3.75" stroke crank for a 400ci, or a 4.00" stroke crank for a 427
Old Jan 7, 2010 | 10:49 PM
Engine: 414 stroker
Transmission: th350
Axle/Gears: 3:70
Re: 408 sb
so we talked to a few machine shops and the place that we are getting block from and cnc machined they say it will fit, we are using a pre 85 block with 2 pc seal, 4" crank and 6" rod have pistions on order to they are a custom set not sure on brand or compresion height yet. it will be bored out to 4.060 total displacment will be 414 with a 64cc aluminum head, we figure it should put out around 500 hp and a lot of torque, and be able to handle a shot of juice to down the road. all forged crank, pistion and rods. will also be trying out the zero gap rings to, with a 4-7 swap cam. will update when more parts show up.
has any one used the zero gap rings are they better then the regular rings
408 84 z28
Jun 5, 2007 12:44 PM
91rs5.0
Apr 18, 2005 11:03 PM
soon2B_best91RS
Aug 9, 2003 10:49 PM
zboss86
Jan 7, 2002 03:01 PM
