1986 Z28 LS Swap Engine wiring help
Car: 1986 Z28, 1989 RS
Engine: 6.0 LQ4
Transmission: TH350
Axle/Gears: Stock, 4:11
Hello, I am doing my 1st. ls swap and need some guidance please, going with a Holley Terminator X and want to remove some things stuff not needed from the main harness.
I believe I will be okay with a little starting help.
Thanks,
Thanks,
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: 1986 Z28 LS Swap Engine wiring help
Engine: 6.0 LQ4
Transmission: TH350
Thanks but did not really find what I was looking for in the links.
Guess all I really need is a engine compartment schematic for a 86 z28.
Thanks in advance
Thanks in advance
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Car: 92 Firebird
Engine: 4.8 LR4
Everything you need is in that link, the Holley is really not much different than doing any other LS swap if you extrapolate the data.
**Le sigh, from the previous link**
https://www.thirdgen.org/forums/ltx-...p-3rd-gen.html
Read. Then read some more. Then go back and re-read. All the information has been covered on the car side
Car: '89 Firebird
Engine: 7.0L
An original factory service manual will have all the schematics. Everything was printed in books back then so search for and buy the book.
I didn't have the book when I did my car, so I had to backwards engineer everything. I found some documentation on this site that gave me an idea what was where, and then sat down with a multimeter and checked all my connector pinouts and documented what was what for my car. Would have been easier with the right service manual.
I have enough documentation in my build thread to get you going, and then you can tailor it to your car which will be a little different.
