Needed Roller cam cradle and lifter holders
Old Jan 17, 2002 | 10:20 AM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
I need a roller cam cradle and lifter holders for OEM roller lifters. Anybody have a set cheap or have the GM part nos so I can get from www.gmpartsdirect.com I could also use a timing chain cover, oil pan for 1pc seal crank, and a set of centerbolt valve covers. Just stock pieces, nothing special.
Old Jan 17, 2002 | 11:01 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Comp Cams could hook you up with what you need at a decent price and it's better than the OEM stuff. Doesnt hurt to give 'em a call and see what they can do!
Old Jan 17, 2002 | 11:53 AM
I don't need the actual lifters just the retainer and cradle. Since these are essentially non wear items, its a chance for someone to get some $$ out of there old dead 305.
Brian
84z96L31vortec
Aug 20, 2017 12:16 AM
camaro71633
Sep 1, 2015 10:24 AM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
anesthes
Aug 8, 2015 09:37 PM
