tbi question - 350 swap 1992 Camaro RS
Old Dec 7, 2021 | 06:18 PM
ACarp's Avatar
Hi, I have a GM create motor 350 ci/300 hp with a single rear main seal. Generic engine, I believe it's called Gen III, but not sure.
Currently my 1992 Camaro RS 25th Anniversary Convertible has a 305 E engine with tbi. My question is will my wiring harness fit a tbi from a 350 pickup engine?
That's the $64 thousand dollar question (man I'm dating myself).
Old Dec 7, 2021 | 06:58 PM
vf750rider's Avatar
Car: 1992 Teal RS
Engine: 350 Carbed
Axle/Gears: 4th Gen Rear 3.42
Re: tbi question - 350 swap 1992 Camaro RS
https://www.thirdgen.org/forums/tbi/...-350-swap.html
Old Dec 7, 2021 | 07:36 PM
vorteciroc's Avatar
Top Answer: 1
Hopefully you purchased a Gen-I Small Block Chevrolet Engine... a 350 cubic inch Engine usually is.
A Gen-III Engine swap is much more involved (also requires more Parts) than a Gen-I swap.
Did your new Engine come with an Intake-manifold and TBI Throttle-Body?
...if so, the Engine is definitely a Gen-I Engine, and that will be a much easier swap.
Some of the existing Wiring can be re-used, such as:
-Connections to the Starter Motor Solenoid.
-Ignition-Coil and Distributor.
-Alternator.
-Oil Pressure and Coolant Temp.
-Knock Sensor.
-Electric Cooling Fans.
-Etc.
The Connectors for the TBI Unit may be different... but most other connections will be at the very least similar.
Old Dec 7, 2021 | 09:41 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Plug and play , just use a 1227747 ecm from
a 87-91 truck automatic or manual whatever your running.
if you don’t have larger injectors from
a 350 you will need those too.
Makeitreal81
Jun 3, 2021 06:22 PM
canes
Jan 17, 2015 06:29 PM
tilerob79
Nov 1, 2008 01:39 PM
UTT2006
Jun 10, 2007 11:12 PM
eZe
Feb 27, 2004 04:04 PM
