Will charging wire current interfere with signal wires?
Old Feb 12, 2022 | 10:27 AM
885speed's Avatar
Car: 1988 Camaro
Engine: LR4
Axle/Gears: 3.23posi/disc
Looking for a little insight from those with more wiring experience than me. This is a subject I've tried to do some searching on, but haven't found much of a solid answer. So instead of assuming this won't be an issue I'd rather ask.
Been working on my gen 3 LS swap for about two years now. I started with a truck harness and have most all of it done at this point minus running all my main powers and grounds in the engine bay.
More specifically I want to run the charging wire from the alternator in the same loom as the injectors/sensors, the idea is to keep everything as neat and clean as I can.
On newer cars I've seen this done with no issue, but also I've kept in consideration that newer electronics are probably better at filtering out interference/noise.
As of right now the experience I do have with 12v circuits and common sense tells me that as long as I have solid grounds I should be okay.
Is this correct?
Old Feb 12, 2022 | 02:01 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: Will charging wire current interfere with signal wires?
It's 14.6v DC, so there's no reason it should cause a problem. You should never run AC right next to DC or signal wires...
Old Feb 12, 2022 | 06:37 PM
vorteciroc's Avatar
Top Answer: 1
Ideally you would not want to do this...
However, I will say that it is far less of a concern with an OEM PCM.
For anyone that is using an Aftermarket PCM/ cares about accurate Data/ can't afford any "Hick-Ups" at the Track...
Avoid do this.
davidjr74
Jun 30, 2012 05:09 AM
MadCelt
Feb 23, 2012 08:28 AM
oif0709
Nov 15, 2011 07:52 PM
graywolf624
Dec 20, 2003 04:04 PM
