Ls7 crank in LS3 for dry sump
Car: 86 z28
Engine: 383 stroker over 30
Transmission: 700R4 B&M shiftkit chevy servo
Axle/Gears: 373 posi..
I’m wanting to go with a dry sump setup because I do track. I’ve got an LS3 that I’m looking to decrease the stroke to 3.9. With an ls7 crank is what I was thinking. I’ve tried searching through the forums and haven’t found many going this route. I saw something about the grand sport having a dry sump on it. I’m just trying to figure out my options and the best route to go. Any advice? All of this is going on an 86 z28
should I go for the aviaid dry sump kit?
Car: '89 Firebird
Engine: 7.0L
Re: Ls7 crank in LS3 for dry sump
I think an LS7 is an even 4.0 inch stroke.
If you want a GM dry sump then you need a long nose crank and you'll need to do the opposite of this, https://www.thirdgen.org/forums/ltx-...-dry-sump.html
GM dry sump oil pump is marginal for real track use if you want to turn over ~6K rpm. The belt-driven multi-stage pumps are better choice for track duty, but it's expensive and does not use LS7 oil pan. AVIAID and Dailey Engineering are two that come to mind.
Car: 86 z28
Car: '89 Firebird
Engine: 7.0L
Then in that case the challenge is just finding a home for the oil tank. You can see where Detroit Speed put it in this thread, https://www.thirdgen.org/forums/memb...ispreloading=1
If you're using GM pump, then a Katech ported pump is a good idea. It will extend rpm capability a ways.
Car: 86 z28
