An LT1 Intake Question
Old Jan 18, 2002 | 07:50 PM
Tyler-88's Avatar
what would i need to have the intake working with my non-lt1 block/aftermarket heads, probably afr 195's. i know id need, the intake, fuel rails, throttle body... to make this function properly, would i need the maf, and what should i do about the ecm? get a custom burnt prom or use the lt1 ecm?
by the way, i need an lt1 itnake
Old Jan 18, 2002 | 08:24 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
As long as you are already TPI, you will use all the existing wiring, sensors and computer.
Old Jan 18, 2002 | 10:03 PM
Tyler-88's Avatar
well, what are the odds, my stocker is a tbi. how hard was it to tune the lt1, or did you?
Old Jan 19, 2002 | 07:26 AM
Engine: 4.0L
Well since you have TBI you must first convert to TPI minus the intake. There are plenty of tech articles on that floatingaround the net.
Yes I tuned the computer, it will not run good unless some tuning is preformed. I tune alot.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
kyle5647
Aug 15, 2015 11:56 PM
