What is the largest engine 3rd gens can take?
Old Aug 31, 2022 | 01:57 AM
blackgloves's Avatar
Car: 1987 IROC-Z
Engine: 6.2L
Transmission: Stage III T56
Big blocks? Which ones?
Old Aug 31, 2022 | 04:59 PM
vorteciroc's Avatar
Top Answer: 1
Re: What is the largest engine 3rd gens can take?
Neither a Short or Tall Deck BBC fit well...
(Headers especially)
But the Tall Deck Engines are definitely worse.
Old Sep 1, 2022 | 06:58 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Nothing like a little 632 bbc
Old Sep 2, 2022 | 05:38 PM
That thing is NOTHING LIKE "putting an ENGINE into a CAR". It's more like, "wrapping a CAR around an ENGINE".
Old Sep 2, 2022 | 10:10 PM
Car: 1987 IROC-Z
Engine: 6.2L
out of all the common big blocks, which fit without butchering up the car? Im assuming the 632 doesnt fit unless cutting is involved?
Old Sep 3, 2022 | 01:26 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
I had a standard deck oval port BBC in my car and it fit fine but like said earlier the exhaust options are not great. I had Lemons make me some tri-Y headers that ran down the tunnel like a set of SBC long tubes would. But after all that you'll still have to use a wheezy intake to clear a stock hood. If you don't mind a cowl then you can get a proper intake and let the engine breath more.
Honestly, a BBC is rather silly unless you build a drag car and get happy with using a cowl hood. If you want a fast car that can corner then get a stroker aluminum SBC or LS engine. The LS engine will fit under a stock hood unless you want a single plane intake.
Old Sep 3, 2022 | 08:40 AM
TTOP350's Avatar
Bolts in on stock sbc mounts. GM has been putting bbc in the 3rdgens since 82. One of their test cars even has dual 3" exhaust
Old Sep 3, 2022 | 03:26 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
A lousy picture for trying to see engine install detail, but it shows you a Rat can fit in quite nicely, and look fairly stock doing it.
First photo in this post. https://www.thirdgen.org/forums/memb...ml#post6470695
Old Sep 4, 2022 | 08:42 PM
Car: 1987 IROC-Z
Engine: 6.2L
No drag racing. Just a cruiser type. I have a LS third gen now. I'd like to have another. The big block sound is unique
Old Sep 4, 2022 | 09:15 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
My tall deck 555 fits fine with 4” cowl and motor plates and custom fabbed headers.
a tall deck can get you 632” and 900-1000 hp all motor easily for a streetable machine
a custom sheet metal intake would be needed for stock hood clearance and im not sure how much room there is with stock hoods
Old Sep 4, 2022 | 10:18 PM
vorteciroc's Avatar
Top Answer: 1
Before having to move the Cylinder-Bore Centers (via an Aftermarket Cylinder Block)...
As Orr89Rocz just said; with the very last 0.025 (Cylinder-Bore diameter) of an Inch, of safety (Cylinder-Wall thickness)...
638 Cubic Inches is as Big as things can get (BBC GM Tall-Deck Cylinder-Block).
Aftermarket BBC Cylinder Blocks are another story...
Depending on the Manufacturer, 900+ to 1,000+ Cubic Inches are on the table!
bahsarie
Mid-West Region
Mar 11, 2007 11:25 PM
1991L98G92
Jun 24, 2006 05:05 PM
