head swap trouble
Old Oct 27, 2022 | 08:12 PM
Bobby Suth's Avatar
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
head swap trouble
I pulled the heads off a 85 iroc engine. Went to install them on a 88 Camaro non roller engine. The guide pins on the block and passenger side are not set up the same. The 85 head has the front pin in it. The engine block has both pins so that the front pin is in the way of the pin that is in the head. Are the pin's removable? I tried to get one out and it doesn't move
Old Oct 27, 2022 | 09:56 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
Re: head swap trouble
OK. I took the risk and vise grip the stud on the 85 head. Gently wiggled and work it out. I needed the bolt pattern angle for a carbureted intake manifold. Going into a 84 firebird
Old Nov 1, 2022 | 03:32 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
What is the cylinder head casting number
under the valve cover?
Truth is the 4 center intake bolt holes can be elongated oval shaped enough to accomodate the other type head. Add a wedge shaped washer under the bolt head to correct clamping angle.
The Weiand Street Warrior Dual Plane Mid-Rise SBC intake is available in both the 55 -86 year and 87 up angled bolts style. #8125/#8126
Fits both a Qjet spreadbore flange or Holley- eddy 4150 flange.. Better intake than a common performer. More underhood clearance than the eddy RPM hirise manifold.
Recaro trans am
Nov 6, 2011 07:29 AM
bradley23150
Aug 14, 2011 02:24 PM
1QWIKZ
FAQ Board
May 5, 2005 05:22 PM
devilfish
Apr 28, 2003 08:48 AM
ZZ28ZZ
Mar 26, 2003 05:51 AM
